Gas Gauge Not Accurate - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 05-09-2006, 10:18 AM Thread Starter
msb1766
I have an 05 Durango STL with the Hemi, The gas gauge is not reading accurately, The needle was half way between 3/4 and Empty filled the tank, it took 18 gallons of gas to fill it up. Any one else having this problem.
msb1766 is offline
post #2 of 9 Old 05-09-2006, 10:28 AM
jeromejenkins
lostsoul trapped in time
jeromejenkins's Avatar
Arrow
Did you mean the needle was at 1/4 and empty? The tank is a 27 gallon tank and with each 1/4 of a tank being approx. 6.75 gallons of gas, 18 gallons when the needle is at the 1/4 mark sounds correct.
2004 Dodge Durango Limited
White
-4.7L Magnum V8 (Nope, it's not a Hemi....Baby Hemi)
-205MM Front Axle
-3.92 Rear Axle Ratio
-Corporate 8.25 Rear Axle
-Tow Package
-Magnaflow exhaust kit (cat-back bolt-on)
-2" Front Torsion Lift
-Airaid Jr. Air Intake (coming soon)
-368 watt Infinity 8 speaker sound system w/6 disc cd player
-Adjustable gas/brake pedals
-Heated leather seats/mirrors
-Removed rubber intake flap
2005 Dodge Durango SLT (Gone but not forgotten)
-Deep Molten Lava Red
-3.55 Gears AWD (no tow package)
-Chopped off resonator/2nd muffler for throatier sound
-Sony M630 Headunit
-Kicker L5 10" Solo-Baric (2ohm setup)
-Kicker KX400.1 (450RMS@2ohm)
-Official Dodgetalk.com sticker (Nope, it doesnt add 5hp)
Gen II Durango Chopped Resonator Member #2 Click here for more info!
Dodgetalk.com Durango Club Member #21
Click here to join!
jeromejenkins is offline
post #3 of 9 Old 05-09-2006, 11:08 AM
abcone
Quoted: 1 Post(s)
My 2005 does the same. When the needle is on E the most I been able to get into it is 21.5 Gallons.
2005 Durango Hemi Lmited
abcone is offline
post #4 of 9 Old 05-09-2006, 11:29 AM
jeromejenkins
I've gotten 29gallons (topping off) into the tank from E. Did this during my last trip from pittsburgh to philly a few months back. I also think that is what triggered my Service Engine light to come on when I filled up the 2nd time in philly.
White
-205MM Front Axle
-Tow Package
-Sony M630 Headunit
Click here to join!
post #5 of 9 Old 05-09-2006, 09:31 PM
GlassJoe
GlassJoe's Avatar
I've had my Limited D w/ a HEMI for about 6 months I am one of those people who take it down as far as I can without refueling - just for the stupid thrill of it I guess. Anyway, I have never been able to get any more than 23.5 gallons in my tank. I've read where it has a 27 gallon tank but when my needle hits "E" and the electronic guage says 0 miles left, it only takes 23 or so gallons to fill it back up. I did post something on this very topic several months ago and was told that when the electronic fuel capacity readout reflects 0 you have about 30 or so miles as a reserve until the D will stop running. 30 or so miles equates to about 2-3 gallons of petro with the HEMI so 23.5G at E + 3G on reserve is right on the money with the 27 gallon advertised capacity.
GlassJoe is offline
post #6 of 9 Old 05-10-2006, 01:05 AM
tnielsen
The Durango's have a 3-4 gallon reserve. The fuel pump is located inside of the gas tank and in order to keep it lubricated, it needs gas. He said the 3-4 gallons insure that the pump will not burn up. When it reads "E" or 0 Mile DTE you have about 3-4 gallons left, but try not to test it. If the fuel pump burns up, it can cost lots of $$$$.
tnielsen is offline
post #7 of 9 Old 05-17-2006, 12:57 PM
1st_dodge
I experience the exact same problem but I found that I can squeeze another 4.5 to 5 gallons into the tank even after the gas nozzle does the auto-off. My uneducated guess is that too much pressure is building up in the fuel tank neck which is causing the fuel to back-up and therefore triggering the auto-shut off in the gas nozzle. The dealer of course can't duplicate the problem. (Also - had tank replaced under the recall). I'd be curious if you can add fuel even after the auto-off.
1st_dodge is offline
post #8 of 9 Old 05-20-2006, 10:08 AM
gregor7777
Odd indeed...I have had the exact same issue. Ran it to E and I've never added more than 21 gallons or so...thought the 27 gal tank thing was false.
gregor7777 is offline
post #9 of 9 Old 05-24-2006, 06:46 PM
KED_Rango
Our driveway is a little hill - if the needle is reading 1/4 - when I back out and drive away my gas light goes on with the chime and about 5 miles down the road it starts reading acurately again. Very weird and annoying.
KED_Rango is offline
    1999 Dodge Ram 2500 CTD Gas Gauge PierDav5 2G Dodge RAM - General Talk 2 01-30-2006 11:30 AM
    Gas gauge not working??? turbines Dodge Dakota 1st Gen (87 -96) Forum 19 10-17-2005 09:45 AM
    Gas Prices Call for Smarter Tire Care, Says Goodyear HankL 2G Dodge RAM - Sport Truck Talk 8 08-15-2005 09:50 AM
    Gas gauge not working GlassBlower 3G Dodge RAM - General Talk 4 09-03-2003 03:10 PM
