Thread Tools |
oil pressure switch location ? 2.7
- Posted: 05-08-2006, 05:47 PM
Post #1
This is something I havent changed before. 03 Intrepid w/2.7. Any hints ?
| Sponsored Links | |
Advertisement |
Posted: 05-08-2006, 08:30 PM
Post #2
I found it. It took some searching, but I found it. So to anyone else down the road that may be looking for the same:
First, make sure the engine is cool obviously & you need a special socket to take this off ($5 at your auto parts store). From under the car, it is near the passenger side front of the block. When you're under the car, look to the right of the oil pan. It should be green & there is a clip on there that Ive never dealt with before. To take it off, you will see a red tab on top of the clip. One side of the tab needs to be pinched & then it slides thru to the other side. Once you slide it over, the harness will slide right off of the oil pressure switch. Heres a hint that I learned the hard way- Once you remove the old switch, you will be bathed in oil if you are in its path. Hope that helps someone. -Matt |
| Thread Tools | |
| R/T Oil Pressure | BlakeO | 1G Dodge Durango General Talk | 1 | 02-10-2006 10:05 AM |
| Where to find Engine Codes | doug_mi | 1G Dodge Durango General Talk | 15 | 08-22-2005 07:14 AM |
| Need help locating the Oil Pressure Switch on a 2.4 DOHC Engine | tmbrian | 2G Dodge Stratus - General Talk | 1 | 08-14-2005 05:09 PM |
| water temp sender and oil pressure switch???? | porcelien | Dodge Caravan/Grand Caravan Talk | 2 | 08-12-2005 09:50 AM |
| Location of 2.5 L V6 oil pressure switch? | HankL | 2G Dodge Stratus - General Talk | 2 | 10-27-2002 12:33 PM |
Privacy Statement | |
