I´ve got an error-code from the ECU today, what does it mean?
- Posted: 05-07-2006, 06:40 PM
Post #1
Hi!
Today when i was driving my Dodge i got an error-code. The "Check Engine"-light came on. I used my cellphone to record all the blinks so i didnt miss a blink. The car is a Dodge RAM B250 Royal Van -88, engine: 318 TBI (5.2litre). Where can i find a error-code-list for my engine? Here is the videoclip: Mp4 1mb http://media.putfile.com/ECU-Error-code Avi 13.1mb http://media.putfile.com/ECU-33 What does the ECU say? What is wrong with my van? Last edited by Elajten : 05-07-2006 at 06:53 PM. |
| Sponsored Links |
Posted: 05-07-2006, 07:02 PM
Post #2
OK I counted 12, 26, 33 and 55
the one to look for is 26 The others are 12 battery disconnected 26 ? 33 a/c clutch relay 55 end of codes
2002 Ram 1500 Sport 4x4 4/5.5" SuperLift Suspension Lift BFG 35x12.5x18 Mud Terrain T/A's 18" Weld Racing Mountain Crushers AVIC-N1 Pioneer deck w/XM & voice command many, many other mods |
Posted: 05-07-2006, 07:13 PM
Post #3
But i don´t have an AC. 26 is: "Peak injector circuit voltage has not been reached (need to check computer signals, voltage reg, injectors) (SEE NOTE #4 BELOW)" And the "#4 Below" is: "During cranking, the computer will test the current through the injector to see whether there's too much resistance in the injector's path. If there is, code 26 is set. The problem may be cured with tuner cleaner on the connectors. For TBI engines, the injector's cold resistance should be between 0.9 and 1.2 ohms (specs vary with year). This is a peak-and-hold injector. With the engine idling the peak period should be about 1.2 milliseconds whereas the hold period will vary. If it's lower than this at idle, then the injector's shorted or there's a defect in the injector driver circuit. (Bohdan Bodnar)" It has been running 100% on E85 (85% Ethanol, 15% gasoline). Maybe the E85 has loosen som dirt that may have clogged the injectors? (excuse me, my english sux, i´m from sweden) 12 is the battery, i had to jumpstart the van yesterday because the battery was drained. Why does the check engine light only show error sometimes? is the injector only a little clogged? So it works fine sometimes and works bad sometimes? Would my problems go away if i change the injectors? |
Posted: 05-09-2006, 02:12 PM
Post #4
If you have access to non-E-85 fuel, I would run a couple of tanks through and see if the 26 clears up.
Your van should not be running on that stuff unless you have made some mods to the injectors.
Grant |
Posted: 05-09-2006, 03:04 PM
Post #5
My manual to the car says that i can mix gasoline and Ethanol. I must increase fuelpressure so it will run better on E85. |
Posted: 05-09-2006, 09:06 PM
Post #6
If you were stateside, I'd say to get another injector assembly from a salvage yard.
I would ask if you tried a different injector assembly, but I am guessing junk yard supplies are few and far between as far as American makes go. I can see where increasing fuel pressure would help to run E-85. Do you have an adjustable regulator on it? It might not hurt to post in the same generation of pickups too.
Grant |
Posted: 05-10-2006, 06:29 AM
Post #7
Is the idle adjustable on my Dodge? Because i feels that i´m beeing rearended almost everytime i put in Drive. The same generations of pick-ups, is it the D250´s then? |
Posted: 05-27-2006, 07:50 PM
Post #8
Hi!
I have replaced the injectors now. And there is no difference. The engine is still running bad =( I have done compressiontest and the results were: * 9.8 bar was the highest result * 8.5 bar was the lowest result The manual said that it could be a 10% difference, and that difference is accepted. It is good results. The sparkplugs look like this: ![]() The white color indicates to "lean mixture" right? The fuelfilter has not been replaced for 6 months, sinse i stopped running the engine on Ethanol. When i changed it 6 months ago, the engine was running lean, just like it does now. The fuel-filter change did only improve the performance by 2%. The fuelpump is new. What could cause the engine to run lean? What is malfunctioning? |
Posted: 05-28-2006, 11:37 AM
Post #9
A bad coolant temp sensor or a bad O2 sensor could cause the engine to run lean.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 05-29-2006, 07:52 AM
Post #10
Code 26: "Peak injector circuit voltage has not been reached (need to check computer signals, voltage reg, injectors) (SEE NOTE #4 BELOW)" And the "#4 Below" is: "During cranking, the computer will test the current through the injector to see whether there's too much resistance in the injector's path. If there is, code 26 is set. The problem may be cured with tuner cleaner on the connectors. For TBI engines, the injector's cold resistance should be between 0.9 and 1.2 ohms (specs vary with year). This is a peak-and-hold injector. With the engine idling the peak period should be about 1.2 milliseconds whereas the hold period will vary. If it's lower than this at idle, then the injector's shorted or there's a defect in the injector driver circuit." What does the "bold" text mean? Code 33: "Air conditioning clutch relay circuit open or shorted (may be in the wide-open-throttle cutoff circuit)" Why do i get this code? I don´t even got a A/C-system. Why don´t i get codes about O2-sensor or coolant temp-sensor? Is my ECU broken? Is there any problem with the injector-wiring? |
Posted: 05-29-2006, 11:26 AM
Post #11
Too much resistance could be a physical problem in the wiring somewhere....like maybe the wire is broken in some spots and there's only a few strands of wire carrying the load.
Defect in the driver circuit would be an ECM problem. Ignore the code 33. Since it's obviously a "dummy" code.
Posted: 05-29-2006, 12:05 PM
Post #12
| Sponsored Links |
Posted: 05-30-2006, 10:26 AM
Post #13
I'll try and get a schematic posted for you this evening.
| Thread Tools | |
| overdrive pulleys Shipping today!! | Got Hemi??? | 3G Ram Performance Talk | 8 | 02-04-2006 11:07 PM |
| Did my tone ring mod today.. | Dodgezilla | 3G RAM Diesel Talk | 11 | 10-08-2005 09:13 PM |
| Dodge Van B250 5.2L Auto Only 1 injector working - ECU Code 27 - HELP!!!???!!!??? | Mdudik | Ram 1st Gen (88 - 93) Forum | 6 | 10-06-2004 12:06 AM |
| Sponsored Links |
