Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
bobo35
  Air Conditioning Controls - Posted: 04-22-2006, 12:35 PM
Post #1
Hi; New guy here. I'm the original owner of a "94 dodge B350 van. During a cold snap I used my heater and now when I turn the AC on the cold air blows out the floor (?) vents. Any help would be appreciated...Thanks
SLW
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
Dodgevanman
 Posted: 04-23-2006, 11:59 AM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #2
The HVAC system uses vacuum to open and close various doors in the plenum to direct air where it is needed. I suspect a broken vacuum line, faulty vacuum diaphrams or bad controls. Get yourself a factory service manual....I found one for my '94 off of Ebay kinda cheap.
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Click HERE to view the complete signature...
bobo35
 Posted: 04-23-2006, 04:04 PM
Post #3
Thanks will do. SLW
bobo35
 Posted: 04-29-2006, 02:02 PM
Post #4
Nate;
I found a service manual on Ebay. It's on disk and not much except it pointed out that I had a cable actuated plenum rather than one driven by vacuum. I've got worse problems today...something let loose in the front end and now the thing is very hard to steer. Thanks for your help. SLW
Dodgevanman
 Posted: 04-30-2006, 06:05 PM
Do It In A Van
State: MD
Post #5
It's both actually. The cable controls the temperature, but it uses vacuum to direct air to the floor, dash vents, or defroster vents. Here's a vacuum diagram for the HVAC for '94:
Nate the skate
5.2L Magnum
318/2bbl.
1985 B150
318/2bbl.
bobo35
 Posted: 05-01-2006, 07:36 PM
Post #6
Thanks Nate; I appreciate the trouble you went to get this.
Thanks again.
1994 Coachman Saratoga
bobo35
  Talking  Posted: 05-13-2006, 07:38 PM
Post #7
OK Sports fans...got it figured out; or rather my tech did. He found three
( countem 3! ) leaks in the vacuum line. got that fixed and after an AC recharge I'm blowin cold again. He also found the right front brake very worn and did a brake job..also found that the factory ( 1994? ) had installed the rear brake adjuster backword and fixed that. this guy was great!
Thanks all for your help.
bobothreefive
K & N Aircharger on 5.7 Hemi seattli 3G Ram Performance Talk 7 07-25-2006 07:44 PM
Air Intakes witch one? KMPX2 3G Ram Performance Talk 49 01-26-2006 01:36 PM
Computer Codes 2nd Gen OBDII Afterfx Neon - General Talk 2 08-14-2005 08:58 PM
HELP!!! Code P0132 SHADOW QUAD CAB 2G Dakota General Talk 4 04-30-2005 10:00 PM
