Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
car54
  pcm problems - Posted: 04-21-2006, 08:25 PM
Post #1
well, I thought I knew the problem but it may not be so. I got a pcm from a local salvage yard and it seems to have the identical problem!!! I checked the ground, ignition feed both are fine. The wire feeding the crank and cam sensors only has 2 volts to ground and it slowly rises but with the new pcm I charged the battery(interstate) and in two hours got to 3 volts. I am sure it is a weak transistor and I do have a spare now to confirm my suspicions. the pcms have identical numbers(56028435, which the dodge dealer says is a typo, should be 56028436 but both pcm's have same numbers so I am pretty sure they are correct). I put my scanner on it but it tells me it is not communicating). In any event I will try to heat it up with a hair dryer. The MIL still won't flash any codes but it did light up on the old one after it quit but stayed on. I wonder if it needs to be re-flashed. I disconnected the battery thinking it would reset but no luck. Any ideas on this? I am thinking that if I can get it to start it will somehow reset itself and relearn
Superchips damaged PCM?? mullinax05 3G Ram Performance Talk 110 04-09-2006 12:13 PM
Downsides of Mopar PCM?? Haeusser 2G RAM - General Talk 28 04-29-2005 09:24 AM
pcm problems wetbar 1G Durango General Talk 0 04-27-2004 05:48 PM
Pcm Needs Replacing 99DODGEDRIVER 1G Durango General Talk 5 04-08-2004 02:27 PM
