So i replaced a alternator on a 2004 neon and while putting everything back together i was trying to loosen the bolt to put that little brace that goes from the motor mount bolt to the inner wheel snapped now the bolt is still ok on the motor mount side but i cant get that bracket on well i can but i wouldnt be able to tighten the bottom now is that bracket required for safe operation of the vehicle the custom is planning on having the front lower motor mount replaced i just wanna make sure the cars still ok to drive untill then also do the front lower mounts come with new bolts?
