Today, we had a 2004 Dodge Ram 1500 4x4. We installed a 1-2.5" Top Gun Customz Torsion Key Leveling Lift Kit. Dodge's front torsion bar suspension on their 02-05 Ram 1500's caused these trucks to sit about 2.5" out of level from back to front. Our torsion bar relocation keys are a great way to level your truck and do away with the factory nose-down stance.
Many vehicle manufacturers (General Motors, Dodge, Ford, and others) have utilized the torsion bar front suspension design with their IFS (Independent Front Suspension) vehicles. This interesting design maintains your vehicle's ride height, and allows smooth suspension travel, by capitalizing on the physical nature of a simple solid steel bar. Given the right amount of resistance, this solid steel bar will twist (or "torse") to allow suspension travel. Then, when that pressure is released, the steel will return to its' original shape. The vehicle manufacturers have pre-set your vehicle's torsion bar angle to provide the stance that they think is correct. Our torsion bar relocation keys allow you to fully adjust your vehicle's torsion bar angles to obtain the stance that you (and nearly everyone but the manufacturers) are after: A level stance where the front and rear of the truck sit evenly off the ground. Finally, let's not forget one of the most important features: Our torsion bar key leveling kit allows you to fit bigger tires!
We also installed 2 brand new Rough Country 8000 Series Front Shocks. These are specifically designed for 4x4 trucks with 0" to 2" of front suspension lift
Recommended Tire Sizes:
+285/75R16 (at 2.5" lift height)
Kit Contains:
+(2) Torsion Keys
+Detailed Instructions
Installed Components:
(2) Rough Country 8000 Series Shocks
(Choose a component for a link to the product)
If you would like to know more about any of the components installed check out our
Top Gun Customz Store for these very products!
Also, if you have any questions about this kit or the components used, please feel free to contact us Toll Free at 1-877-274-9362. or you can e-mail us at sales@topguncustomz.com
