Top Gun Customz 2" Leveling Lift Kit On A 07 Dodge 2500 4x4 Diesel
Today, we just finished on a 2007 Dodge 2500 4wd Diesel. We installed a our very own Top Gun Customz 2" Doge Ram Leveling Lift Kit.
On our Top Gun Customz Leveling lift Kits the highest quality materials are used including zinc plated hardware and nylon-locking nuts. Because these are so unique and easy to install, they are "NOW PATENTED". Also, with the polyurethane kits, a spacer is installed BETWEEN the coil spring and the top of the strut. That puts preload on the spring which noticeably stiffens up the ride. With ours, you simply unbolt the strut from the vehicle, install the steel spacers on top of the strut and bolt everything back up. RIDE QUALITY IS UNCHANGED. This kit does wonders for the look of your new truck. It is recommended that you have the alignment checked after installation. This kit comes with all hardware which is zinc plated and complete instructions. The spacers are offered in black finish.
We also installed 2 New Rough Country Nitrogen Shocks for better ride quality on this power house of a 4x4 2500!
Top Gun Customz Leveling Lift Kit...
+ New "Now Patented" Design
+ 3 support studs welded in
+ Installs in as little as 1 hour.
+ Does NOT require spring compressor or disassembly of the strut like ALL the poly kits do.+ Does not affect ride at all.
+ Made from 1/4" thick laser cut steel.
+ Install instructions included.
+ Lifetime Warranty!!
THESE THINGS ARE INDESTRUCTIBLE!
Installed Components:
(Choose a component for a link to the product)
If you would like to know more about any of the components installed check out our Top Gun Customz Store for these very products!
Also, if you have any questions about this kit or the components used, please feel free to contact us Toll Free at 1-877-274-9362. or you can e-mail us at sales@topguncustomz.com
