Hello All
I started my 2000 Dodge 1500 Pickup today and the ABS & Brakes Light came on and stayed on. I also heard a noise coming from under the hood. The ABS pump/motor is on and running and will not shut off. When I turned the truck off the pump is still running. I disconnected the battery and the pump shut off, but when I reconnected the battery the pump came on and is still running. The only way I could turn it off was to remove the ABS fuse from under the hood. It would not turn off when I removed the fuse from the inside of the truck.
Any help with this would be greatly appreciated.
:help: Signguy
:help: Signguy
