We were driving at highway speeds and the car died out of nowhere. Asd relay is not engaging. When I manually engage the relay, there is power to coil packs and injectors, but no power to fuel pump. Cam and crank sensors are both getting power and sending signal back to pcm. I have a remanufactured pcm on the way to see if that will get the car to run.
I'm going to test the wiring this weekend to see why when I engage the Asd relay why I still have no power to fuel pump.
What are possible causes of the Asd relay not engaging?
