Have you tried a CV slide hammer tool on it? I rented one from AutoZone when I did mine several years back...worked like a charm.
If you are talking about the hub side...heat is always your friend when it comes to stuck bolts. A hair dryer will work if you don't have a heat gun handy.
Anytime! Attach your gear puller with some good tension on it and hit it with some heat while gradually increasing the tension on the puller. Also, if you haven't yet, I'd spray some Liquid Wrench or similar on it which will assist in the whole process.
