The closest thing i have seen to my problems was titles 96 intrepid electrical problems / battery.
This is the deal. The intrepid is a 95 with about 130,000. The battery in the car croaked on me, and thus replaced it. Since the replacement i cannot get the interior lights to dim off unless the car is running. Also the power door locks do not work (unless running, and then only unlock works). replace the door switches, to no avail. After the car is turned off before exiting the vehicle, if you attempt to use the door locks the interior lights come on, by the way ignition switch was replaces two months ago (would not allow the key to come out of the column), all fuses and relays check out fine.
any help would greatly appreciated...
