So after having my trans serviced (band adjustment, fluid & filter change) I was informed that the "plug" that goes in the middle of the driveshaft yoke at the transfer case was missing and was causing my fluid leak.
They showed me on the lift and there is a big ass hole where a plug / plate goes to block off fluid coming from the trans case.
Anyone have any idea where I can get a replacement or what size said plug is? The trans shop said they could try and tack weld a piece of something in there or replace the yoke, but I didn't have the funds for it at the time.
I purchased a rubber freeze plug looking piece that I'll try and fit, but I have to drop the drive shaft and separate the yoke to get access to it.
I am hoping if I can get something about the right size in there and use some RTV that it will hold.
Any advice input is welcome appreciated...
