6.1 intakes make power to abotu 6100 I've seen a few peak as high as 6300. They are hard to beat in the mid range though. From what I'm hearing even the high dollar sheet metal intakes aren't doing better. I haven't seen any 09 intake dynos but I have a couple customers that have switched to them and both have run better than with the older car intake although the older car intake doesn't make peak RPM as high as the truck intake does. The truck intake is actually a little higher RPM
Adam said Davids truck kept pulling all the way to 6300 rpms...... He also said the Spartan Max pulled better up top while maintaining virtually the same mid range as the Spartan.......
Good numbers, i can't wait to get my heads installed!
Related Threads
DodgeTalk Forum
4.7M posts
290.1K members
Since 2002
