I have been working on a friends D and when I scaned the little darling I got 8 errors! P0201 thrue P0208 !! The engine runs but not great and even stalls now and then. All of this could be injectors but all 8 of them ??? I expected that maybe a ground or something common to all was the culprit but no luck yet.
they will all have a common power source and the computer grounds each one with individual drivers. it is either fuse/relay,related power supply OR bad connection at pcm. do wiggle test on dark green/orange striped wires(common power feed). switch asd relay with another(or replace). i suspect power side as it is common fed. drivers are all individual. let me know if you need a wiring diagram, good luck
Related Threads
DodgeTalk Forum
4.7M posts
290.1K members
Since 2002
