trouble codes - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 1 Old 01-30-2006, 03:02 AM Thread Starter
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
trouble codes
thought i would list trouble codes for anyone who needs them....good luck
TROUBLE CODES FOR 87-94 for
Dodge Shadow , Plymouth Sundance & Duster
CODE# DESCRIPTION
11 no distributor reference signal detected during engine cranking. Check the circuit between distributor and the computer.
__________________________________________________ _______________
12problem with stand-by memory circuit. Direct battery input to controller disconnected within the last 50 ignition key-ons
13indicates a problem with the map sensor pneumatic (vacuum) system
14 map sensor voltage too low or too high
15 a problem with the vehicle distance/speed signal. No distance/speed signal detected during road load conditions.
16loss of battery voltage
17 engine is cold too long. Engine coolant temperature remains below normal operating temperatures during operation (check the thermostat).
21 problem with oxygen sensor signal circuit. Sensor voltage to computer not fluctuating.
22 coolant sensor voltage too high or too low. Test coolant temperature sensor.
23 indicates that the throttle body temperature sensor/ charge temperature sensor input is below the minimum acceptable voltage or the throttle body temperature sensor input is above the maximum acceptable voltage.
24 throttle position sensor voltage too high or too low. Test the throttle position sensor.
25 automatic idle speed (AIS) motor circuits indicate a shorted condition detected in one or more of the circuits. Check the circuits
26 peak injector current has not been reached (non-turbo) or a problem with an injector circuit (turbo). Check the injectors and electrical harnesses.
27 one of the injector control circuit output drivers does not respond properly to the control signal. Check the circuits.
31 problem with the canister purge solenoid circuit.
32 an open or shorted condition detected in the EGR transducer solenoid circuit. Possible air/fuel ratio imbalance not detected during diagnosis.
33 air conditioning clutch relay circuit. An open or shorted condition detected in the air conditioning clutch relay circuit.
34 open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
35 radiator fan relay circuit indicates an open or shorted condition.
36 indicates a problem with the waste gate solenoid circuit(turbo models) or the air switching solenoid circuit(non-turbo).
37 Torque converter unlock solenoid circuit. An open or shorted condition detected in the toque converter part throttle unlock solenoid circuit(automatic transaxle models only)
41 problem with the charging system. Occurs when battery voltage from the ASD relay is below 11.75-volts.
42 auto shutdown relay (ASD) control circuit indicates an open or shorted circuit condition.
43 problem with the spark interface/injection control circuit.
44 no FJ2 voltage present at controller. Failure in the computer.
45 map sensor reading above over boost limit detected.
46 charging system voltage too high. Computer indicates that the battery voltage is not properly, regulated. Check the computer.
47 charging system voltage too low. Battery voltage sense input below target charging voltage during engine operation and no significant change in voltage detected during active test of alternator output.
51 oxygen sensor signal input indicates lean fuel/air ratio condition during engine operation.
52 oxygen sensor signal input indicates rich fuel/air ratio condition during engine operation.
53 internal computer failure detected.
54 problem with the distributor synchronization circuit.
55 completion of fault code display on check engine lamp. This is an “end of message” code.
62 unsuccessful attempt to update emr mileage in the controller EEPROM.
63 controller failure. EEPROM write denied. Check the SMEC or computer
Jmw132001 is offline
    2000-2004 trouble codes biztec Dodge Neon - General Talk 2 03-13-2006 11:39 PM
    trouble codes funtimesdak 2G Dodge RAM - General Talk 4 10-25-2004 05:28 PM
    98 G.C. Trouble codes Cnd_Stratus Dodge Caravan General Talk 2 10-20-2004 08:44 PM
    Dodge Trouble Codes rickj Vintage Dodge Car Forum 2 09-27-2004 10:30 PM
