Ok so I have another post called hot plugs in dealing with a possible blown intake gasket. This thread is about modifying the tps on a stock tb. In searching for a new tb, I came across an article on modifying the tps in .1 volt increments. I am wondering has anyone done this and does it work with a stock tb or not?
Modification is drilling out the plastic sleeves and then rotating it to increase or decrease voltage.
If you have what results have you seen?
http://www.hughesengines.com/Index/...Vt&searchmode=partnumber&page=30&partid=28352
Click on install sheet at bottom of page.
