It is time to replace my front brakes and figured bearings as well, but I am quite confused as to the part number I should purchase. I've read a few threads here and have seen cases where the bearings don't fit the rotors so I want to make sure I have correct part numbers.
Details of my van:
1997 B3500
Non-ABS (I think), codes from under hood sticker:
BGJ _ POWER BRAKES - FRT DISC/RR
DJD - 3600 FRONT AXLE
From the mopar part manual this looks like Mopar 04086830 for the hub and rotor assembly.
The number of combinations is quite large and it looks like in some cases this can be an issue. Would someone mind posting a link to rockauto or other store of hub/rotor assembly that fits the specs above?
Thank you!
Details of my van:
1997 B3500
Thank you!
