May 10, 2004
01 SLT/ Durango 5.9L
Need advice. My wife called me at work one day to tell me the check engine light came on. When I got home it was off. I ran the code and got "P0601 -- Internal Control Module Memory Check Sum Error" The truck seemed to be running fine and I didn't have time to mess with it. The check light came on few days later when I was driving. When we got home it was late and I went to bed, the next morning the light was off again. I ran the code again and got the same P0601.
What would be causing this?
Thanks
#3
May 18, 2004
Try this, disconnect the negative battery terminal and then hold the ignition key in the start position for atleast 20 seconds, this will wipe out all stored codes in the PCM. Reconnect the negative battery terminal and drive, if the code shows up again then it is time to go to the dealer. Depending on miles this should be covered under warranty, because it has to with emmisions. Hopes this helps.
Nebel50
2000 Durango
Slightly modified
#4
May 28, 2004
code check
Many of the auto stores (AutoZone, PepBoys, etc.) do free diagnostics when the check engine light comes on. Mine usually comes on after an engine mod and I bring it to AutoZone. They check it out and will reset it if I ask. This has always solved my problem (the check engine light will trip again if its a real problem and not a computer 'glitch').
#5
May 30, 2004
It is funny that I just had this code come up on my Durango with a 4.7. What came of your problem? Should I be worried? I have 38,000 miles on it.
#6
Jun 2, 2004
I had a 1998 Dodge durango with a 5.2, and had the same problem. Every time i hit 3,000 RPMS (6,000 rpms tach), My Check engine light would come on. But every time i started the engine every 3 times, it turned off.
Easy fix- Take the dash apart and take out that bulb
I was told by autozone it was a oxygen sensor, which cost a hell of alot of money to fix, since i already spent TONS of money last summer to just slightly keep it running.
just take the bulb that lights up the "check engine light" or change the oxygen sensor, that should solve it.
-nate
#7
Jun 5, 2004
Well I took my D to the daeler and basicly that code is cut and dry. The PCM is shot, There is not anything else that will cause p0601 code. It is covered under the 80k emmisions warenty, so it, atleast is no cost to me.
Hope this helps someone in the future.
EMC
#8
Jun 11, 2004
Here are all the codes!!
Chrysler/Dodge DTC Code Interpretation
P0016 Crankshaft/Camshaft Mis-align/sync
P0030 1/1 02 Sensor Heater Relay Malfunction
P0036 1/2 02 Sensor Heater Relay Malfunction
P0071 Ambient Temp Sensor Performance
P0072 Ambient Temp Sensor Low
P0071 Ambient Temp Sensor High
P0088 Fuel Rail Pressure High
P0101 MAF Sensor Performance
P0102 MAF Sensor Low frequency
P0103 MAF Sensor High frequency
P0106 Barometric Pressure Out of Range
P0107* Map Sensor Voltage Too Low
P0108* Map Sensor Voltage Too High
P0111* Intake Air Temp Sensor Performance
P0112* Intake Air Temp Sensor Voltage Low
P0113* Intake Air Temp Sensor Voltage High
P0116 Coolant Temp Sensor Performance
P0117* ECT Sensor Voltage Too Low
P0118* ECT Sensor Voltage Too High
P0121* TPS Voltage Does Not Agree With MAP
P0122* Throttle Position Sensor Voltage Low
P0123* Throttle Position Sensor Voltage High
P0125* Closed Loop Temp Not Reached
P0126 Insufficient ECT for Stable Operation
P0128 Cooling System Error / Thermostat Performance
P0130 1/1 02 Sensor Heater Relay Malfunction
P0131* 1/1 02 Sensor Shorted To Ground
P0132 1/1 O2S Shorted To Voltage
P0133 1/1 O2S Slow Response
P0134 1/1 O2S Stays At Center
P0135 1/1 O2S Heater Failure
P0136 1/2 02 Sensor Heater Relay Malfunction
P0137 1/2 O2S Shorted To Ground
P0138 1/2 O2S Shorted To Voltage
P0139 1/2 O2S Slow Response
P0140 1/2 O2S Stays At Center
P0141 1/2 02 Sensor Relay
P0143 1/3 O2S Shorted To Ground
P0144 1/3 O2S Shorted To Voltage
P0145 1/3 O2S Slow Response
P0146 1/3 O2S Stays At Center
P0147 1/3 02 Sensor Heater Failure
P0148 Fuel Delivery Error
P0151* 2/1 02 Sensor Shorted To Ground
P0152* 2/1 02 Sensor Shorted To Voltage
P0153* 2/1 02 Sensor Slow Response
P0154* 2/1 02 Sensor Stays at Center
P0155* 2/1 02 Sensor Heater Failure
P0157* 2/2 02 Sensor Shorted To Ground
P0158* 2/2 02 Sensor Shorted To Voltage
P0159 2/2 02 Sensor Slow Response
P0160* 2/2 02 Sensor Stays at Center
P0161* 2/2 02 Sensor Heater Failure
P0165 Starter Relay Control Circuit
P0168 Decreased Engine Perf Due To High IP Fuel Temperature
P0169 Water-in-fuel detected for too long
P0171* 1/1 Fuel System Lean
P0172* 1/1 Fuel System Rich
P0174* 2/1 Fuel System Lean
P0175* 2/1 Fuel System Rich
P0176 Loss of Flex Fuel Calibration Signal
P0177 Water In Fuel
P0178 Water in Fuel Sensor Volts Too Low or
P0178 Flex Fuel Sensor Volts Too Low
P0179 Flex Fuel Sensor Volts Too High
P0180 CNG Temp Sensor Voltage Fail
P0181 Fuel Injection Pump Failure
P0182 CNG Temp Sensor Voltage Too Low
P0183 CNG Temp Sensor Voltage Too High
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201* Injector #1 Control Circuit
P0202* Injector #2 Control Circuit
P0203* Injector #3 Control Circuit
P0204* Injector #4 Control Circuit
P0205* Injector #5 Control Circuit
P0206* Injector #6 Control Circuit
P0207 Injector #7 Control Circuit
P0208 Injector #8 Control Circuit
P0209 Injector #9 Control Circuit
P0210 Injector #10 Control Circuit
P0215 Fuel Injection Pump Control Circuit
P0216 Fuel Injection Pump Timing Failure
P0217 Decreased Engine Perf Due To Engine Overheat Condition
P0219 CKP Sensor Overspeed Condition
P0220 APP Sensor 2 Circuit
P0221 APP Sensor 2 Circuit Performance
P0222 APP Sensor 2 Circuit Low Voltage or
P0222 Idle Validation Signals Both Low
P0223 Injection Pulse Width Error (Rise Time Long) or
P0223 Idle Validation Signals Both High (5 Volts)
P0225 APP Sensor 3 Circuit
P0226 APP Sensor 3 Circuit Performance
P0227 APP Sensor 2 Circuit Low Voltage
P0228 APP Sensor 2 Circuit High Voltage
P0230 Transfer Pump (Lift Pump) Circuit Out Of Range
P0231 Fuel Pump Feedback Circuit Low Voltage
P0232 Fuel Shut-Off Signal Voltage Too High
P0234 Turbo Boost Limit Exceeded
P0236 MAP Sensor Too High Too Long
P0237 MAP Sensor Voltage Too Low
P0238 MAP Sensor Voltage Too High
P0243 Open or shorted condition in the Wastegate solenoid control
P0251 Fuel Injection Pump Fuel valve Feedback Circuit
P0252 Fuel Injection Pump Fuel Valve Stuck
P0253 Fuel Injection Pump Fuel Valve Open Circuit
P0254 Fuel Injection Pump Fuel Valve Current Too High
P0263 Cylinder 1 Balance System
P0266 Cylinder 2 Balance System
P0269 Cylinder 3 Balance System
P0272 Cylinder 4 Balance System
P0275 Cylinder 5 Balance System
P0278 Cylinder 6 Balance System
P0281 Cylinder 7 Balance System
P0284 Cylinder 8 Balance System
P0300* Multiple Cylinder Misfire
P0301* Cylinder #1 Misfire
P0302* Cylinder #2 Misfire
P0303* Cylinder #3 Misfire
P0304* Cylinder #4 Misfire
P0305* Cylinder #5 Misfire
P0306* Cylinder #6 Misfire
P0307* Cylinder #7 Misfire
P0308* Cylinder #8 Misfire
P0309* Cylinder #9 Misfire
P0310* Cylinder #10 Misfire
P0320 No Crank Reference Signal at PCM
P0325 Knock Sensor #1 Circuit
P0327 Knock Sensor Noise Channel Low Voltage
P0330 Knock Sensor #2 Circuit
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0339 Crankshaft Position Sensor Circuit Intermittent
P0340* No Cam Signal At PCM
P0341 CMP Sensor Signal
P0342 ESS Voltage Supply Low
P0343 ESS Voltage Supply High
P0350 Ignition Coil Draws Too Much Current
P0351* Ignition Coil # 1 Primary Circuit
P0352* Ignition Coil # 2 Primary Circuit
P0353* Ignition Coil # 3 Primary Circuit
P0354* Ignition Coil # 4 Primary Circuit
P0355* Ignition Coil # 5 Primary Circuit
P0356* Ignition Coil # 6 Primary Circuit
P0357 Ignition Coil # 7 Primary Circuit
P0358 Ignition Coil # 8 Primary Circuit
P0370 Fuel Injection Pump Speed/Position Sensor Signal Lost
P0380 Intake Air Heater Relay No. 1 Control Circuit or
P0380 Glow Plug Circuit Performance
P0381 Wait To Start Lamp Inoperative
P0382 Intake Air Heater Relay No. 2 Control Circuit
P0387 CKP Sensor Supply Voltage Too Low
P0388 CKP Sensor Supply Voltage Too High
P0400 Exhaust Gas Recirculation (EGR) Flow Malfunction
P0401* EGR System Failure
P0403* EGR Solenoid Circuit
P0404* EGR Position Sensor Rationality
P0405* EGR Position Sensor Volts Too Low
P0406* EGR Position Sensor Volts Too High
P0410 AIR System
P0412 Secondary Air Solenoid Circuit
P0420* 1/1 Catalytic Converter Efficiency
P0430 1/2 Catalytic Converter Efficiency
P0432* 1/2 Catalytic Converter Efficiency
P0440 Evap System Performance
P0441* Evap Purge Flow Monitor
P0442* Evap Leak Monitor Medium Leak Detected
P0443* Evap Purge Solenoid Circuit
P0446 Evap Emissions Vent Valve Performance
P0452 Evap Emissions Pressure Sensor Circuit Low Volts
P0453 Evap Emissions Pressure Sensor Circuit High Volts
P0455* Evap Leak Monitor Large Leak Detected
P0456 Evap Leak Monitor Small (0.020) Leak Detected
P0460 Fuel Level Unit No Change Over Miles
P0461 Fuel Level Unit No Changeover Time
P0462 Fuel Level Sending Unit Volts Too Low
P0463 Fuel Level Sending Unit Volts Too High
P0475 EPR Solenoid Circuit
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan1 Control Circuit Open (Low speed fan)
P0483 Cooling Fan Speed
P0500* No Vehicle Speed Sensor Signal
P0501 Vehicle Speed Sensor Performance
P0505* Idle Air Control Motor Circuits
P0506 Idle Control System Low RPM
P0507 Idle Control System High RPM
P0508 Undercurrent condition detected in linear IAC mtr feedback sense circuit
P0509 Over current condition detected in linear IAC mtr feedback sense circuit
P0514 Battery Temp Sensor Performance
P0516 Battery Temp Sensor Low
P0517 Battery Temp Sensor High
P0521 Oil pressure Sensor Performance
P0522 Oil Pressure Sensor Low
P0523 Oil Pressure Sensor High
P0524 Oil Pressure Too Low
P0532 A/C pressure Sensor Low
P0533 A/C pressure Sensor High
P0541 Intake Air Relay 1 Low
P0542 Intake Air Relay 1 High
P0545 A/C Clutch Relay Circuit
P0551* Power Steering Switch Failure
P0560 System Voltage
P0562 Charging System Voltage Too Low
P0563 Charging System Voltage Too High
P0567 Cruise Resume Circuit
P0568 Cruise Set Circuit
P0571 Cruise Brake Switch Circuit
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0575 Cruise Switch Failure (Shorted)
P0577 Cruise Switch Failure (Open)
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0600* PCM Failure SPI Communications
P0601* PCM Internal Controller Failure
P0602 ECM Fueling Calibration Error
P0603 VCM Memory Reset
P0604 RAM Check Failure
P0605 ROM Check Failure
P0606 ECM Failure
P0607 ECU Internal Performance
P0615 Starter Relay Control Circuit
P0621 Alternator L Terminal Circuit
P0622* Alternator Field Not Switching Properly
P0628 Fuel Pump Relay Circuit Low (or)
P0628 Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High (or)
P0629 Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Ref Voltage 1 Circuit Low
P0643 Sensor Ref Voltage 1 Circuit High
P0645 A/C Clutch Relay Circuit Performance
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0650 Malfunction Indicator Lamp (MIL) Circuit
P0652 Sensor Ref Voltage 2 Circuit Low
P0653 Sensor Ref Voltage 2 Circuit High
P0654 Engine Speed Output Circuit
P0698 Sensor Ref Voltage 3 Circuit Low
P0699 Sensor Ref Voltage 3 Circuit High
P0700* EATX Controller DTC Present
P0703* Brake Switch Sense Circuit
P0704 Clutch Switch Circuit (M/T)
P0711 Trans Temp Sensor, No Temp Rise After Start
P0712 Trans Temp Sensor Voltage Too Low
P0713 Trans Temp Sensor Voltage Too High
P0720 Low Output SPEED Sensor RPM, 15 MPH
P0740* Torque Converter Clutch, No RPM Drop at Lockup
P0743 Torque Converter Clutch Solenoid/Trans Relay Circuits
P0748 Governor Pressure Sol Control/Trans Relay Circuits
P0751 O/D Switch Pressed (Low) More Than 5 Minutes
P0753 Trans 3-4 Shift Sol/Trans Relay Circuits
P0756 AW4 Shift Sol B (2-3) Functional Failure
P0783 3-4 Shift Sol, No RPM Drop at Lockup
P0801 Reverse Gear Lockout Circuit Open or Short
P0830 Clutch Depressed Switch Circuit
P0833 Clutch Released Switch Circuit
P0837 4WD Switch Performance
P0838 4WD Switch Circuit Low
P0839 4WD Switch Circuit High
P1000 Ignition Circuit Low
P1001 Ignition Circuit High
P1004 ECU Battery Feed & Power Grounds
P1005 System Ground Circuit
P1006 EGR/EVAP Solenoid Circuit Low
P1007 EGR/EVAP Solenoid Circuit High
P1008 Power Steering Circuit Low
P1009 Power Steering Circuit High
P1012 MPA Circuit Low
P1013 MPA Circuit High
P1014 Fuel Pump Circuit Low
P1015 Fuel Pump Circuit High
P1016 Charge Air Temperature Circuit Low
P1017 Charge Air Temperature Circuit High
P1018 Serial Data Circuit
P1019 Power Latch Not Set
P1021 Engine Failed To Start Due To Mechanical, Fuel or Ign Conditions
P1022 Starter Relay Circuit Low
P1024 ECU Start Circuit Low
P1025 WOT Circuit Low
P1026 WOT Circuit High
P1027 ECU Sees Wide Open Throttle
P1028 ECU Does Not See Wide Open Throttle
P1029 ISA Closed Throttle Circuit Low
P1030 ISA Closed Throttle Circuit High
P1031 ECU Sees Closed Throttle
P1032 ECU Does Not See Closed Throttle
P1033–36 ISA Circuits
P1037 TP Sensor Circuit Reads Low
P1038 Park/Neutral Line High
P1039 Park/Neutral Line Low
P1040 Latched B+ Line Low
P1041 Latched B+ Line High
P1042 No Latched B+ 1/2 Volt Drop
P1043 Shift Lamp Circuit Grounded
P1044 D2–1 Circuit Low (A/T) or
P1044 Upshift Lamp Circuit (M/T) or
P1044 Shift Lamp Circuit High
P1045 Shift Lamp Circuit Open
P1047 Wrong ECU
P1048 M/T Vehicle Configuration
P1049 A/T Vehicle Configuration
P1050 Idle RPM Low
P1051 Idle RPM High
P1052 MAP Sensor Out Of Limits
P1053 Change In MAP Reading Out Of Limits
P1054 Coolant Sensor & 5 V for TP Sensor/MAP Circuits Low
P1055 Coolant Sensor Circuit High
P1056 Inactive Coolant Temperature Sensor
P1059 A/C Request Circuit Low
P1060 A/C Request Circuit High
P1061 A/C Select Circuit Low
P1062 A/C Select Circuit High
P1063 A/C Clutch Circuit Low
P1064 A/C Clutch Circuit High & Power Steering Input
P1065 Rich Oxygen Sensor Input
P1066 Lean Oxygen Sensor Input
P1067 Latch Relay Circuit Low
P1068 Latch Relay Circuit High
P1069 No Tach
P1074 ECU Does Not See Speed Sensor
P1106 MAP Sensor Circuit Intermittent High Voltage
P1107 MAP Sensor Circuit Circuit Intermittent Low Voltage
P1110 Decreased Engine Perf Due To High Intake Air Temperature
P1111 IAT Sensor Circuit Intermittent High Voltage
P1112 IAT Sensor Circuit Intermittent Low Voltage
P1114 ECT Sensor Circuit Intermittent Low Voltage
P1115 ECT Sensor Circuit Intermittent High Voltage
P1121 TPS Circuit Intermittent High Voltage
P1122 TPS Circuit Intermittent Low Voltage
P1125 Accelerator Pedal Position System
P1133 HO2S Insufficient Switching Bank 1 Sensor 1
P1134 HO2S Insufficient Transition Time Ratio Bank 1 Sensor 1
P1153 HO2S Insufficient Switching Bank 2 Sensor 1
P1154 HO2S Insufficient Transition Time Ratio Bank 2 Sensor 1
P1180 Decreased Engine Perf Due To High IP Fuel Temperature
P1191 Intake Air Duct Leak
P1192 Inlet Air Temp Sensor Voltage Low
P1193 Inlet Air Temp Voltage High
P1194 02 Heater Performance
P1195* 1/1 02 Sensor Slow During Catalyst Monitor
P1196* 2/1 02 Sensor Slow During Catalyst Monitor
P1197 1/2 02 Sensor Slow During Catalyst Monitor
P1198 Radiator Temperature Sensor Volts Too High
P1199 Radiator Temperature Sensor Volts Too Low
P1214 Injection Pump Timing Offset
P1216 Fuel Solenoid Response Time Too Short
P1217 Fuel Solenoid Response Time Too Long
P1218 Injection Pump Calibration Circuit
P1271 Accelerator Pedal Position Sensor 1-2 Correlation
P1272 Accelerator Pedal Position Sensor 2-3 Correlation
P1273 Accelerator Pedal Position Sensor 1-3 Correlation
P1275 Accelerator Pedal Position Sensor 1 Circuit
P1277 Accelerator Pedal Position Sensor 1 Low Voltage
P1278 Accelerator Pedal Position Sensor 1 High Voltage
P1280 Accelerator Pedal Position Sensor 2 Circuit
P1281 Engine is Cold Too Long
P1282 Fuel Pump Relay Control Circuit or
P1282 Accelerator Pedal Position Sensor 2 Low Voltage
P1283 Idle Select Signal Invalid or
P1283 Accelerator Pedal Position Sensor 2 High Voltage
P1284 Fuel Injection Pump Battery Voltage Out Of Range
P1285 Fuel Injection Pump Controller Always On or
P1285 Accelerator Pedal Position Sensor 3 Circuit
P1286 Accelerator Position Sensor Supply Voltage Too High
P1287 Fuel Injection Pump Control Supply Voltage Low or
P1287 Accelerator Pedal Position Sensor 3 Low Voltage
P1288 Intake Manifold Short Runner Solenoid Circuit or
P1288 Accelerator Pedal Position Sensor 3 High Voltage
P1289 Manifold Tune Valve Solenoid Circuit
P1290 CNG Fuel System Pressure Too High
P1291 No Temp Rise Seen From Intake Heaters
P1292 CNG Pressure Sensor Voltage Too High
P1293 CNG Pressure Sensor Voltage Too Low
P1294* Target Idle Not Reached
P1295 No 5 Volts to Throttle Position Sensor
P1296 No 5 Volts to MAP Sensor
P1297* No Change in MAP from Start To Run
P1298 Lean Operation at Wide Open Throttle
P1299* Vacuum Leak Found (IAC Fully Seated)
P1336 Crankshaft Position System Variation Not Learned
P1345 Crankshaft Position/Camshaft Position Correlation
P1351 Ignition Control Circuit High Voltage
P1361 Ignition Control Circuit Low Voltage
P1380 Electronic Brake Control Rough Road Data Unusable
P1381 Misfire Detected-No Electronic Brake Control Data
P1388 Auto Shutdown Relay Control Circuit
P1389 No ASD Relay Output Voltage at PCM
P1390* Timing Belt Skipped 1 Tooth or More
P1391* Intermittent Loss of CMP or CKP
P1398* Misfire Adaptive Numerator at Limit
P1399 Wait to Start Lamp Circuit
P1403 No 5 Volts to EGR Sensor
P1404 EGR Valve Closed Pintle Position
P1406 EGR Valve Position
P1409 EGR Valve System leak
P1415 AIR System Bank 1
P1416 AIR System Bank 1
P1441 Evap Emissions Flow During Non-Purge
P1475 Auxiliary 5 Volt Supply Voltage High
P1476 Too Little Secondary Air
P1477 Too Much Secondary Air
P1478* Battery Temp Sensor Volts Out of Limit
P1479 Transmission Fan Relay Circuit
P1480 PCV Solenoid Circuit
P1481 EATX Misfire RPM Signal out of Range
P1482 Catalyst Temperature Sensor Circuit Shorted Low
P1483 Catalyst Temperature Sensor Circuit Shorted High
P1484 Catalytic Converter Overheat Detected
P1485 Air Injection Solenoid Circuit
P1486* Eva Leak Monitor Pinched Hose Found
P1487 Hi Speed Radiator Fan CTRL Relay Circuit
P1488 Auxiliary 5 Volt Supply Output Too Low
P1489* High Speed Fan CTRL Relay Circuit
P1490* Low Speed Fan CTRL Relay Circuit
P1491 Radiator Fan Control Relay Circuit
P1492* Ambient/Battery Temp Sensor Volts Too High
P1493* Ambient/Battery Temp Sensor Volts Too Low
P1494* Leak Detection Pump Switch or Mechanical Fault
P1495* Leak Detection Pump Solenoid Circuit
P1496* 5 Volt Supply, Output Too Low
P1498 High Speed Radiator Fan Ground CTRL Relay Circuit
P1508 IAC System Low RPM
P1509 IAC System High RPM
P1594* Charging System Voltage Too High
P1595 Speed Control Solenoid Circuits
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
P1598 A/C Pressure Sensor Volts Too High
P1599 A/C Pressure Sensor Volts Too Low
P1602 PCM Not Programmed
P1621 PCM Memory performance or Write
P1626 Vehicle Theft System Control Loss of Data
P1627 A/D Performance
P1630 Vehicle Theft System PCM in Learn Mode
P1631 Vehicle Theft System Improper Password
P1635 5 Volt Reference (A) Circuit
P1639 5 Volt Reference (B) Circuit
P1641 MIL Control Circuit
P1643 Wait To Start Lamp Control Circuit
P1646 5 Volt Reference (C) Circuit
P1652 J1850 Communications Bus
P1653 EGR Vent Solenoid Control Circuit
P1654 Service Throttle Soon Lamp Control Circuit
P1655 EGR Solenoid Control Circuit
P1656 Wastegate Solenoid Control Circuit
P1680 Clutch Released Switch Circuit
P1681 No I/P Cluster CCD/J1850 Messages Received
P1682* Charging System Voltage Too Low
P1683 Speed Control Power Relay; or S/C 12v Driver CKT
P1684 Battery Disconnected in the last 50 Starts
P1685 Skim Invalid Key
P1686 No SKIM BUS Messages Received
P1687 No Cluster BUS Message
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Comm between ECM & Injection Pump Module
P1690 CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel System ESS RPM Error
P1692 DTC Set In ECM
P1693 DTC Detected in Companion JTEC Module
P1694 No BUS Message Received from ECM Module
P1695 No CCD/J1850 Messages from the Body Control Module.
P1696* PCM Failure EEPROM Write Denied
P1697* PCM Failure SRI Mile Not Stored
P1698* No CCD/J1850 Message From TCM/PCM
P1719 Skip Shift Solenoid Circuit
P1740 TCC or O/D Solenoid Performance
P1756 Gov Press Not Equal to Target @ not15-20 PSI
P1757 Gov Press 3 PSI in gear with 0 MPH
P1762 Gov Press Sensor Offset Volts Too Low or High
P1763 Governor Pressure Sensor Volts Too High
P1764 Governor Pressure Sensor Volts Too Low
P1765 Trans 12 Volt Supply Relay CTRL Circuit
P1899* P/N Switch Stuck in Park or in Gear
P2121 Pedal Position Sensor 1 Performance
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Position Validation Switch 2 Low
P2128 Pedal Position Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2147 Fuel Injector Group 1 Supply Voltage Low
P2148 Fuel Injector Group 1 Supply Voltage High
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2150 Fuel Injector Group 2 Supply Voltage Low
P2151 Fuel Injector Group 2 Supply Voltage High
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Voltage Low
P2504 Charging System Output Voltage High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
