So my project for the weekend was to replace my brake pads, rotors, hoses, calipers. I've had to empty 3 big bottles of brake fluid in the reservoir but still ends up empty. But now my exhaust is smoking like crazy. I have oil so that's not the problem. Any help?? Thanks!
If it is burning your brake fluid then i would guess your master cylinder and/or power booster has gon bad and your engine is sucking the brake fliud into your intake and burning it, but i would be leaning to a really bad master cylinder.
+1. ... Check the big vacuum line that supplies vacuum to booster, it should be dry inside; handle the 90* plastic fitting at booster carefully, they are known to break.
I am thinking you are going to need a new power booster, i have had many master cylinders leak in the rear but have never had my engine suck up brake fluid.
Related Threads
DodgeTalk Forum
4.7M posts
289.9K members
Since 2002
