I'd also check the Toyo Open Country A/T II's. That being said, you can't disable the TPMS System. Hopefully AEV has something up their sleeve when they release the ProCal later this year.
Okay, Jack provided me what I needed. Discount tire misinformed me that 35s didn't have higher psi than 50. now knowing some go up to 65psi, that will solve my problem. thanks
New Info. This showed up on the AEV forums. It looks like the info you need to take with you to your dealership to get the TPMS reprogrammed correctly.
"The dealer will have to put the low tire pressure threshold in the body control module BCM to desired air pressure's.. then the run the function in the Radio Frequency Hub RFH. "RFH replaced" (not actually replacing it) when they run thus function it will transfer the desired air pressure thresholds from the BCM to the RFH. Keeping the cluster from saying you have low tire preessure's. I've done it multiple times.. and was actually the only one to figure out how at my dealer. *(also was the only one who figured out you can set 5500 mph goviner to 86mph vs 76) "
I run 35" Cooper Discovery STT's on mine and max psi on them is 65 psi. They've been a great tire on and off road.
I'll be replacing them with 37" tires when I wear these out.
Related Threads
DodgeTalk Forum
4.7M posts
289.9K members
Since 2002
